any advice for a log home?
im doing my first log home tomorrow. aside from the obvious things (water intrusion, rot, wood destroying insects, etc…) can anyone give me any advice?
thanks in advance
Bob
Hi, Bob. All of these may be helpful to you:
http://www.nachi.org/loghomedisclaimer.htm
http://www.logassociation.org/resources/standards.php
http://www.nachi.org/loghomes.htm
http://www.americanlogrestoration.com/
Another thought…
I’ve built many log homes and I would disclaim the logs part of the stucture if I couldn’t spend the additional time needed to do an adequate inspection of those logs including up high. And that means charging more, a bunch more. There are too many cracks for water to run in. Also the method of construction is important in order to assess the framing attached to the logs. Some methods take into consideration the logs settling approximately 1" per foot of height of log wall. And on and on…
