Any Scribeware users in Texas know a good Template?
So I’ve been wanting to update my Scribeware software and add /edit the comments.
I’m in Texas so it needs to be TREC compliant and use the REI 7-6 form.
I just bought INL (InterNACHI Narrative Library) TREC 7-6 Residential Template and it’s missing several things and needs some work to make it complaint. (I was really hoping it would be plug and play for $250)
Am I doing something wrong?
The Best one I’ve used has been the template that came with Scribeware.
I know I could spend hours making one myself but I was really hoping to find a good answer?
Does it exist or is it a gap in the market?
I appreciate any help or advice.
Spend the time to build your own would be my recommendation. It takes time, but you will be better off for it in the long run.
Post this on the Scribeware site. Call or message Dylan. As you noted, there is a TREC template available. Did you see this?
As an edit, some or all of this template development work is possible to complete on Scribeware using AI. That tool might be helpful… or not.
Yes. I use that template and have done some edits to it myself. I was just thinking to add more/ better worded comments and add things to the optional systems on the template to make them easier/quicker.
Was hoping there was a better template I could just buy but it looks like I need to spend a few days building it out myself I guess.
InterNACHI Narrative Library is exactly what it says it is. It is not a workable template, just a comment library.
Just use your workable template you have now and copy and paste in the comments you want.
Before you purchased it you should have read the description.
this description?
Kenton is working with me to hopefully come up with a solution. I was just a little disappointed because it was worded as a ready to use template. Hopefully we can get it all working and figured out so the next guy doesn’t have any problems.
If he gets this all straightened out it looks like it will be a great resource and I’ll be recommending it. But it’s not ready to use out of the box yet.
I went through what you seem to be describing when I moved to Scribeware - comment editing/migration and template layout. You should talk to Dylan. It became a snag for me, and he was very helpful getting me up and running. There is a subscription plan with lots of support. It was well worth it for me. He might be able to coach you to use AI to complete the template and comment tasks you mention, including Kentons library integration.
I’ve been using the Texas specific template (texas requires we use a certain format for our reports) that came with Scribeware and it honestly really good. But I wanted to get more comments and things so I started researching and read that the one I ordered was supposedly a ready to use template and it sounded awesome so I bought it. Once I got it all set up and started testing it I noticed several things right off the bat that made it not Texas (TREC) compliant (for example we have to have 4 check boxes in every section, inspected, not inspected, not present, and deficient.
We’re also required to give an opinion on the performance of the foundation in our reports and there is no opinion comments) so I’ve spent the day building my own by combining the 2 templates and adding my own things as well.
I think we’re going to be good and I’m sure once I start using it more I’ll find things that need to be tweaked more.
I’ve talked to Kenton so he’s trying to make sure these things get straightened out for people in the future.
Texas just has different requirements then 90 percent of the country apparently.
It’s not very beginner inspector friendly at the moment though. Would recommend any one who gets it sit down with someone with experience to get it set up.
Kenton Shepard is a great guy. I’m sure he will get it all working for you.
He’s been awesome to work with. I think it just because he’s not as familiar with the Texas specific stuff so once that’s ironed out we’ll be set.
