Appliance Inspection for Home Inspectors
This is a photo of an electric range made by Frigiaire. This range has a glass cook top and tempered glass door. I inspected all the springs and gaskets and found them in good working order. The cook top and the oven heat up as directed using the controls.
This is an electric range made by Frigidaire. This range has a glass cooking surface. I inspected the door gasket and springs, and found them to be in good working order. Both, the range and the oven heat up as directed using the provided controls.
My photo is of our French-door style with two doors for the refrigerator on top and one bottom freezer door compartment. It has digital controls to show the temperature of the freezer and the fridge part even the out side temp. It has an alarm for if the any part of the fridge is open it will sound an alarm. I tested the feature and works properly. The lights come on when doors open works properly. Also took a picture of the label of the fridge
A firestop is a passive fire-protection method designed to diminish the opportunity for fire to spread through unprotected openings in a rated firewall. Such openings are found around the perimeter of pipes and wiring that penetrate firewalls.Firestops must seal all unprotected openings in firewalls. In homes, firewalls are found in the following locations:
between the garage and the living space, including the overhead ceiling;firewalls that separate condominium units are often penetrated by utilities that serve multiple units. Common Problems With Firestops are Missing fire Stops.cable or pipe replacement. improper installation,In summary, firestops are designed to prevent the spread of fire through unprotected openings in rated firewalls. Inspectors should understand what they are and what purpose they serve.
The food waste disposer is unusually noisy and the noise sounds like an obstruction is inside the disposer. This can damage the unit and is a potential safety hazard. A qualified licensed plumber needs to evaluate further and remove, repair or replace as necessary.
The type of material a flexible dryer vent connector is made from is important to inspect. They are often made from flexible vinyl, foil, mylar, flexible metal or solid metal duct. Flexible vinyl, foil, mylar and flexible metal can be easily kinked or crushed. Dryer ducts that do not have smooth interior surfaces can trap lint. Additionally, flexible vinyl, foil and mylar should not be used with gas dryers as these can burn through in the event of a dryer fire. It is important to follow the manufactures specifications and current building requirements.
I have opted to exceed the InterNACHI SOPs and inspect kitchen appliances when possible. I test to make sure they turn on and off using standard controls, that they have anti-tip brackets installed, and I make an effort to check for leaks. Leaks are mostly just for dishwashers. My clients expect that these will be tested.
This is a photo of an electric range/oven where 2 of the three burners are not functioning correctly. The oven is heating properly, seals around the oven door are functioning properly. The anti tilt is installed correctly. Though only a minor defect further evaluation is needed by a professionally lincensed repairman.
When inspecting toilets for leaking and or bad performance, I look for tank not secured to the bowl, bowl and tank not secured to the flange. Rusted tank, bowl bolts. Damaged drywall ot the water outlet. Also where applicable, damage to sub-flooring in the crawl space would be your best indicator of water damage. If so I recommend further help from a licensed plumbing contractor.
I chose the article titled " 6 Reasons To Hire A Professional for Your Home Energy Audit". There is a natural connections, because appliances consume a fair amount of the energy used by a home. My company offers an energy audit to clients interested in saving energy, and in saving money. It is another opportunity to add value to our service.
Dishwashers may be permanently installed or portable. Permanent dishwashers operate using the homes electrical and plumbing systems. Maximum recommended water temperature range is 130 degrees F to 170 degrees F. Sprayed water at this temp range using multiple cycles of washing and rinsing assures the load is thoroughly clean. Drying is done using hot, forced circulated air.
Clothes to be dried in an electric dryer can contain up to a gallon or more of water. Dryers evaporate the water by blowing hot air past them while they tumble inside. heat is supplied either electrically or by gas burner. Airborn water vapor will leave the dryer through an exhaust vent or “duct”.
I did an inspection of the shed on my property. The floors were solid, the roof showed no signs of water intrusion. There is electric run to the shed. The ramp leading to the front door was solid and free of decay.
The dishwasher pictured is loose and needs to be secured to either the counter top or surrounding cabinets. This will ensure the dishwasher does not tip when the door is opened resulting in damage to the plumbing lines or injury.
Anti tip brackets for free standing ranges are required. The presence of anti-tip brackets should always be confirmed by the inspector. It may be possible to see the anti-tip bracket or the inspector can firmly grip the handle and pull on the oven. If it tips more than a few inches, then it is missing and needs to be installed.
Included in this picture are the pool pump and sprinkler assemblies. They are similar in size and location, and in this area knowing the difference is important. The sprinkler uses water from a canal located directly behind the house. The size of the pipes reduce down in steps over distances to increase pressure needed to spray a large area.
Types of private water wells,
There are three types of private drinking water wells: dug, driven, and drilled. Proper water well construction and regular maintenance are crucial for the safety of the water supply. The well should be located so that rainwater flows away from it.
Buying a foreclosure
Purchasing foreclosed homes in desirable areas at below-market values can be a sound investment strategy.
there are four ways to buy a foreclosed home: A presale is when the prospective buyer negotiates with the current owner before the house is foreclosed.
A real estate-owned sale is a transaction where a foreclosed house is purchased directly from the bank.
At public auction, in which buyers can expect a discount of 10 to 25 %
by the department of housing and urban development.
I chose to do further research on central vacumes by reading “Central Vacuum Systems” by Nick Gromicko. While written for consumers, I found it interesting because I have never had a central vac system in any of my 8 houses. Having never had one, I did not know the advantages.
RANGE/COOK TOP AND OVEN
Electric, free standing range. The range was turned on using normal operating controls and found to be working satisfactory. Anti-tilt bracket missing at range. This can cause range to fall forward if force is placed on open oven door. Recommend installing ant-tilt bracket to prevent personal injury.
