I’ve searched and searched. Found plenty of pdf files with serial code info, but none like mine. First off it’s blowing cold air which is most likely the 5kw heat strips. Have had strips replaced like 3 times! I thought they only get used with aux or emergency heat? I’ve never used either of those two. Why would they keep blowing? But secondly I’d like to find more info on this old beast. Can anyone help?
Seems like you have looked many places .
Some times it is easier and quicker to call in an expert to have it properly diagnosed to find out the problem
Now that I’ve looked, there’s another place on the unit that has completely different #'s. More on the lines of serial # H404720… So sometime in the mid 80’s i presume.
model: NEBF047AK01
Seems there’s another area on the unit with serial #'s, etc.
model NEBF047AK01…which i presume is a 4 ton unit?
serial: H404720…which i presume is from the mid 80’s?
Anything else that could get me a pdf user manual online?
