Any information on the rules related to the installation of an attic light would be appreciated.
I.E.
Fire Codes
Location
Wattage
Switch
area served (sq feet)
NEC / IRC (other than IRC E3803.4)
Etc.
I.E.
Fire Codes
Location
Wattage
Switch
Etc.
The only requirements are that if that attic is used for storage or the has equipment installed in it that needs servicing, a switch controlled light needs installed at or near the normal entrance. This could be a wall switch or a pull string on the fixture. If there will be employees of a company working on the A/C, the minimum lighting levels are 10 footcandles.
Thank you Marc for reply
