Backfill and foundation walls?
Originally Posted By: smcintire
I have a question concerning concrete basement walls and backfill according to IRC R404.1.7. If the foundation is backfilled prior to the floor being attached are there any problems, other than the short-term possibility off damaging the wall during the backfill operation?
Originally Posted By: rcloyd
Steve:
Foundation walls must be supported laterally at both the top and bottom
prior to backfill. This is to prevent any movement/rotation of the wall.
Failure to do this can cause a failure in the wall system. Ideally, the basement slab should be in place and the first floor joist system installed prior to backfill.
In reality, this rarely happens.
Best Regards,
Russell G. Cloyd
Intra-Spec Home Inspections
& Code Consulting, LLC
859-586-4591
www.intra-spechomeinspections.com
Thanks Russell, I guess it is up to the builder to take that chance with the foundation, and for me to look for the cracks!
