Balcony with diagonal bracing. In this case, the balcony is around 6’x8’ and is supported by two diagonal 4x4 braces. The braces each have one 1/2" lag bolt securing them at each end. The ledger board has standard lag bolt fastener pattern installed. The ledger ends have a small 90 degree bracket nailed in place with joist hangar nails.
I’m looking for a guide to assessing these 45 degree supports.
And or…
Any typical overbuild guide standard, like like some great brackets, or a bolt pattern and material standard for ledgers used with additional pull-out weight requirements.
Hate to just say…I don’t like it…it doesn’t look like it’s strong enough…etc…
Thanks, Bill O
