Basement Floor Drain Confirmation
I am of the understanding that sinks and washers cannot drain to the basement floor drain.
Is this correct? Thanks all.
A residential sink must connect directly into the sanitary drain system. A washer may discharge into the sink or be connected to the sanitary drain via a trapped standpipe. Do you have a picture that you can post?
Exactly… …
no need for a picture. Thanks for confirming that my thinking was correct.
In some areas the washer can to greywater.
The sink, no. Must connect directly to the sanitary system with a trap.
The washer if going to the sanitary system must have an air gap and a trap.
