bathroom spa
Originally Posted By: pmagrone
I recently inspected a home with a spa in the master bathroom. The disconnect was wired to a GFCI outlet in the master bedroom walk in closet. Technically, this is proper, but for the home inspection report I called it like I saw it and suggested it be moved into the master bathroom. Was this correct? icon_question.gif
Originally Posted By: away
Paul,
My home is done the same way. I figured it was for better access to the GFCI receptacle if it trips. Not a whole lot of room on any of the walls to put the receptacle either.
I am curious why you would say that it needs to be moved to the bathroom rather than the closet. As long as the GFCI protection is there, Why does it matter where the actual receptacle is? Would you call it out if the circuit was protected by a GFCI breaker?
I am not trying to challenge or be contentious just trying to understand the logic.
Andrew Way
Keystone Residential Inspection Services PLLC
817.441.9598
www.keystoneinspections.com
Originally Posted By: Blaine Wiley
Most GFCI’s for whirlpool tubs in this area are located in the service panel.
Originally Posted By: phughes
In our area, they can be located in the closet, (just try to find them!) in the toilet area, in the bathroom, in the garage, in the service panel, inside the unit. Just about any place.
Happy hunting !!
Originally Posted By: jmyers
Paul,
If you are speaking in terms of correctness, I think you have fallen short. I don't know of any requirements which would not allow it to be operated from a GFCI receptacle, or even a GFCI receptacle located in the master bathroom closet.
Joe Myers
A & N Inspections, Inc.
http://anii.biz
