Hey guys, I came across a patio cover where the beams/rafters were fastened directly into the side of the posts rather than bearing directly on top. Was a nice patio, but from everything I understand, best practice is for load to transfer down through the post rather than relying on nails/screws on the side. The wood in these areas is already showing rot and the patio will be getting addressed, but I’m curious for future inspections and client interactions. Would you simply call it out as non-standard framing and move on? Appreciate any and all input.
Morning, Erik. Hope to find you well and in good spirits today.
Looks like a full shade sloped patio pergola.
Do you have any more images of what I am referring to as a pergola that include the length and depth, looking upwards?
Randy is very strong and astute on structural connections & building materials used.
Post end should be under beam. Simpson makes brackets to correct the situation shown without disassembly.
At one time it was common practice. Nowadays no longer accepted. Call it out, and as Robert mentioned, aftermarket hardware is available to correct the problem.
Hey Robert, good morning brother. I thought I did have more images, but I guess that was just my mind’s eye, because after checking my phone, that was it. There are 1 or 2 other pictures, but just of the posts, some of which were severely deteriorated.
That’s what I was thinking too. Thanks for the reference to Simpson.
It was soft, so I hit that pretty hard in the report. It was in multiple other locations as well.
Good to know. Info is helpful when explaining to clients, that is, that it use to be common, which is why it may be the way it is, but not an accepted practice anymore.
If you live in a region where you might get a heavy snow load on it, then I might consider calling it out, but if you’re in Florida, Arizona, Southern California or a region with no snow, I wouldn’t be so concerned as long as there’s no visible damage, like the crack @lkage pointed out.
I’d be concerned about high winds uplifting the roof structure if those rafters aren’t properly attached.
In saying that, it’s always best to be safe than sorry, so if you think it’s not suitable or built to current standards, write it up as such.
This is something to note and consider regarding what comments you make in your report.
Down here in the warm south I’d be less likely to call it out unless there was deterioration, as you noted, or there was more of a significant load (i.e. a balcony opened above and allowed access).
Thanks, Kevin. Sounds like a neutral, non-alarming, informational type narrative would fit well for these situations.
Absolutely. Smart
Thanks for the input, Anthony. Appreciate the feedback as it helps me articulate the situation better to clients and agents.
Note the rot and move on…. let the fix-it guy worry about doing it the modern way. Maybe I’m just lazy but I don’t feel our job is to educate the buyers on every change in construction methodology between the time the house was built and the time of my inspection. Sure, there are some important things I do make note of that have changed - GFIs, safety railings…. things like that. I just don’t see this as a hill I want to die on. Especially, with it being an easy fix in the very unlikely event someone were to complain.
