The supply and return pipes for a hot water boiler with baseboards were steel soldered to copper elbows/fittings. I have never seen this before, the steel pipes sounded exactly like tapping on emt conduit and were very thin. They were rusting and leaking and I obviously wrote it up. My question is has anyone seen this before and was this a product that was once used?
There is a difference between soldering and Brazing its a matter of temp, steel flows at one temp and copper flows at another. Old time refrigerators had steel stub outs on their compressors and we had to braze them.
If your magnet says they are steel so be it but I would write the whole mess up as being dissimilar metals joined together
Silfoss is only used for brazing not soldering and the correct flux must be used when trying to braze copper to steel. You can not solder (soft solder) copper to steel has to be brazed only and it does not always hold not many are good at doing that
