Is this a temperature & pressure relief valve or just a relief valve? Does it need to have a T& P valve? Residential boiler. This always confuses me with boilers. Any helpful insight is always appreciated! TIA.
A T&P valve or temperature and pressure relief valve is installed on all modern heating boilers, steam boilers, water heaters, and on certain other pressurized or heated tanks and equipment to release hot water and pressure should the boiler’s internal pressure or temperature rise to an unsafe level.
Some equipment may have only a pressure relief valve with no temperature sensor. On a water pressure tank that’s fine, but on water heaters and steam or hot water heating boilers such an installation is not safe and may not comply with building codes.
TPRV will, in addition to pressure, say at which temperature it will open. If it only mentions pressure, it’s a PRV.
Boilers (hydronic & steam) need a PRV
Water heaters with a storage tank need TPRV.
On demand or instant or wall hung water heaters normally use a PRV.
Ok thx. So that debunks the previous copied and pasted reply then?:
IMO… NO!
Know your source. Which inspector do you trust more?
Imo, the product description seems pretty straight forward that it’s just a PRV but is approved for this application…
Not sure about variances that local jurisdictions may have.
So you slam me for a “copy and paste” when I clearly showed you where it was from. Not trying to take credit just giving you an answer from a reliable source.
I guess I could have replied to your first question
“Is this a temperature & pressure relief valve or just a relief valve?” yes another copy and paste
No it clearly states “RELIEF VALVE”
Chill, Jim, I wasn’t slamming you at all.
So next step, what does the boiler manufacturer require? @jfrederick
