I’ve seen this once or twice before, but I wanted to get any opinions… house built in 1962, roof decking is about 3/4” thick x 5” dimensional laminated planks. It has paper covering, labeled “BOND BORD”. My client saw this, and was asking about it. It seems in good condition, but the paper facing has come loose in a couple of spots. The material under the paper feels like a particle-board consistency. When I walked the roof, it was solid and had no soft spots or deflection. When I searched, I found nothing at all. Curious if anyone has experience with this material..
Not much out there, but did find this.
Bond Bord - Sheet Board - Roof Forum - The Inspector’s Journal
Yeah - I saw that. It doesn’t say much! Thanks
Looks like TW&J Logo, but I didn’t find anything else about this product other than it’s made for roof sheathing and sub floors
Product Details
Composition: BOND-BORD consists of individual wooden boards bonded together and sealed on both sides with 42-lb waterproof building paper.
Usage: It was commonly used in homes built around 1966 as a durable material for roof sheathing.
Manufacturer: The “TW&J” in the logo likely refers to Tarter, Webster & Johnson, a major lumber distributor active during that era.
Important Safety Considerations
While BOND-BORD itself is primarily described as wood bonded with waterproof paper, homes built in the 1960s often utilized materials containing asbestos.
Potential Hazards: Asbestos was frequently used in various construction boards (like cement asbestos board or transite) for fireproofing and strength during this period.
Risk: Materials containing asbestos are generally not a significant health hazard unless they are damaged or disturbed (e.g., by sanding, cutting, or drilling), which can release harmful fibers.
Verification: The presence of asbestos cannot be determined by sight alone and requires professional laboratory analysis.
Lebanon, NH (.gov)
Lebanon, NH (.gov)
+3
If you are planning to renovate or disturb this material, it is highly recommended to have it tested by a certified asbestos inspector before proceeding.
Are you planning to remove or repair this board, or are you just looking to identify it for maintenance
Do you even bother to read the full post before replying?
I swear, you must be related to that Canadian guy in Montreal!!
Mr. Cox is a Home Inspector, and his post stated this…
As Mr. Jonas replied - I am an inspector, and looked to identify the material. But thank you for the information. My client is a young first-time home buyer and I will pass on this info.
My searches didn’t provide any of the above info - thanks for the time and trouble. The roof is about 10 years old, so they will be looking to replace shingles in the future. I will be sure to advise them of the asbestos possibility for that!
I was just posting on what I found. You don’t need to be a dick.
Gold Bond® eXP® Sheathing is a specialized, mold-resistant roof sheathing featuring a gypsum core with fiberglass mats, designed for superior moisture resistance, fire resistance (UL Class A), and 12-month weather exposure. This high-density panel is commonly used as a cover board or substrate in commercial roofing to provide exceptional durability, impact resistance, and a stable surface for adhered roofing membranes.
It’s not Gold Bond, but Bond Bord.
My research online is suggesting that Bond-Bord was a lighter-weight fiber-board material made from wood fibers or cellulose pulp combined with binders (resins or asphaltic compounds) and possible fire retardants or preservatives. It is not as strong as OSB or plywood and even more susceptible to moisture damage, particularly if the paper covering protecting the ends has deteriorated. The paper becomes brittle over time, so the cracking and falling down on the underside is normal for its age. In this case, your walking the roof as well as visual inspection from within the attic are your best evidence that water damage has NOT occurred. However, the next time the homeowner replaces the roof would be a good time to reassess the condition of the sheathing materials and consider replacing with stronger materials less susceptible to water damage.
[quote=“Andrew Cox, post:13, topic:266270, username:acox”]
Bond Bord
So sorry.
From AI.
Bond-Bord (Construction Material)
In the mid-1960s, “Bond-Bord” was also a specialized building material used primarily for roofing.
- Composition: It consisted of individual boards bonded together for increased structural strength.
- Weatherproofing: The panels were sealed on both sides with 42-lb waterproof building paper to protect against moisture.
- Dimensions: It was typically sold in large sheets, with some records indicating panels as large as 2’ x 16’.
Other 1960s “Bond” Contexts
- Financial Bonds: The 1960s saw the introduction of U.S. Retirement Plan Bonds (1963) and Savings Notes, also known as “Freedom Shares” (1967).
- Julian Bond: A prominent civil rights leader who served on the board of several organizations, including the NAACP, and was active in Georgia politics starting in the mid-1960s.
[image]National Archives (.gov) +3
Would you like more details on the collectible value of the board game or the technical specifications of the Bond-Bord building panels?
It seems like you already had your answer, without all of the AI responses given.
64-year old roof sheathing, a material you have seen before, appeared to be in good condition, no soft spots or deflection. Nothing left to say except it seems like a suitable installation.
He just wanted information on a product to relay to his client, not looking for inspection related answers.
