The air handler unit at todays inspection is a Lennox unit with a 7.5 KW heat strips. The unit was drawing 35.2 amps and was on a 100 amp breaker.
The homeowner said he would replace the breaker and wanted to know what size breaker to install.
My question is what size breaker should it be on and am I correct by writing it up as being on an oversized breaker and succeptible to damage. I tried calling the manufacturer and was on hold forever.
Thanks in advance
