Here is the problem?
When I inspect a home it is a visual inspection. I do not us instruments to test the deflection in walls, no do I use scopes inside walls, or so I put arbitrary amounts of pressure on walls ceiling or other components of the home. This is not part of the inspection.
However, the buyers “Friend” an “expert” in home repair does. So he goes around pressing on walls etc. and find if he shoves on one part of one wall he can cause it to move up by the freeze board.
Ok, so to answer the buyer, who has not bought the house, he wants to know why it does this, what is wrong, what has to be done, and why didn’t you see this.
So to actually answer this, I need to know what is the allowable amount of movement, and since it was built 35 years ago, what was the building requirement then.
My guess is I can’t find one.
So if there isn’t a requirement, then it is functioning as designed.
Yes, it may not need this movement, and in general opinions it should not move. But, if it can be moved, then what is the stress factor that should be used to calculate this. Opinions can vary. That is why there are building codes and design requirements. My opinion is not official, neither is the opinion of his friend. Now my wife can’t move the wall, I can move it if I press on it over my head. I don’t know the size of the person that moved it.
So, if it moves, what is the appropriate pressure at what location to determine the affect.
Do any of you test the walls?
