I did a home today with burnt -charred wood trusses and roof sheathing, it has been painted grey , some of the roof sheathing was moisture damaged.
It was disclosed as a past fire, most of the framing appeared stable, what your take on this ??? should these framing have to be replaced?dreamkeeper4u@gmail.com
Looking at pictures of a past fire will do nothing other then solicit unfounded opinions… what it will come down to is what your probing found… I trust you did probe the members in question.
If they are satisfactory to you then simply recommend that documentation be provided by the company that made the repairs.
regards.
jeff
PS. Also have client check for any permits that would have been pulled as a result of the damage…
