CAFCI breaker
(Jeff Merritt) #1
I have a contractor (new construction 2018) saying that an CAFCI circuit breaker is OK to install in bathrooms.I say no, anyone have any info saying yes, I have looked and can’t find anything.
(Larry Kage, CMI) #2
They are not GFCI breakers per Schneider Electric.
Watch short video: Video: What is the difference between an AFI and a CAFI circuit breaker?
(Jim Port) #3
Afci protection can be used if desired in addition to areas that already require it. The receptacles would still need gfi protection.
(Chuck Evans, CMI TREC 7657) #4
It’s perfectly fine so long as he installs GFCI protection at the receptacle. It’s not a substitute or alternative. If he thinks it is, ask him to point out the language in the NEC.
(Robert Meier) #5
Why would you say no even if it weren’t required? Isn’t extra protection a good thing?
(Jeff Merritt) #6
Thanks for confirming what I thought.
(Jim Port) #7
your OP said you thought you could not install them. That is incorrect.
(Don C. Hawley) #8
For an extra $5 they can use a dual purpose AFCI/GFCI breaker and everyone would be happy.
(Jeff Merritt) #9
yes in a bathroom without a GFCI outlet
