The main was installed in a bathroom. The panel was recently installed.
When the new box is installed. Lets say in 2004. Is the electrician required to updqate the home to the latest NEC? There where no visible main ground connections, No exterior ground rod. Ect…
I know the box isnt allowed to be in the bathroom.
It looks like there are some 14 gauge wire to 20Amp breakers. Is the main aluminum wire rated for 100 amps. Looks like #1 or 2. This would be 80 Amps.
Any explanation would be appreciated.
Would like to also add about how other inspectors note bathrooms that have the older light fixture with receptacle? Am I correct in advising that they remove the old fixture & install a light bar and add a GFCI?
Can a 220 line be installed on a board? The one I observed the board was loose.
Thanks
Dave
Paul A. I am looking forward to your class in december. Please make a note that I am attending. I will register soon.
I’ve been told by some electricians, they had to do somethings messed up. “had to do”, like this situation, the electrician probably had no choice since the service cables came in there, or the bathroom was a diy’er job, and it was originally a small office, or etc, etc, etc. The new electrician was following bad work previously made. I usually respond with, “you could have just walked away”.
I dont know how they do it in OHIO, but down here in Florida, they are SUPPOSED to pull a permit for and upgrade (like they ever do), which would require that the box be moved out of the bathroom and that GFCI’s be installed. Also, the ceiling in that picture is not sealed.
I would write it up as an improper installation, listing all the defects that you noted, including that my client do a permit search, and recommend repair by a licensed electrician.
This is an interesting situation.
Up until the 1993 NEC, the panels were permitted in bathrooms. So if this is an upgrade of an existing panel that was approved prior, then the question is would it be required to be relocated when upgraded??? I would call the building department and ask them.
But note that the toilet is directly below the panel… that has never been permitted. [110.26(A)]
