Can anyone think of WHY they did this?
Originally Posted By: dbush
http://www.nachi.org/bbsystem/usrimages/I/Improper_electric_junction.JPG ]
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
Originally Posted By: rbennett
Possible high temp heat switch to cut blower off in case of fire
Need a little more info as to where the wires go
RLB
Originally Posted By: jsmith10
Could it be two booster fans in the duct work(one in each duct)? I cant see the left connections very well, are there wires going into it?
Joe,
Vice-President, Idaho Chapter,
www.NachiIdaho.org
Inspected as though my family are to live or work there.
http://www.Treasurevalleyinspections.com
There are booster fans installed on the heater; however, these wires go directly up the insulation of the flexduct and run up inside it.
Dave Bush
MAB Member
Could they then be for Zone control dampers? Without seeing the system it’s just a guessing game.
And it's fun too.
Joe,
www.NachiIdaho.org
Originally Posted By: rmoore
My guess would be that they are for line-voltage thermostats that sense the duct temperature and “tell” the booster fans when it’s most efficient for them to come on.
I installed (read jerry-rigged) a similar thermostat this year in my TV hole-in-the-wall to aid in cooling the space. The one I ended up with was designed mainly for the duct-work booster fan application.
http://www.suncourt.com/DuctStat.html
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
OK
Industry experts, and industry leaders what is the conlusion
1 It is not visual say nothing (some of it is)
2 Call the professional who installed it
3. Call another professional
3 Say nothing
4 Do further checking because it might be a safety issue that you have publicly documated on the web and not reported
5 Look like a assss to the client for not knowing
5 ETC
7 (you had two 5s)…As all we know for a fact is that we have bad splices…Report it as in need of repair and investigation by a licensed electrician.
Guessing here is fun, but not in my job description.
Richard Moore
Seattle, WA
www.rainspect.com
I did write it up in need of repair of course; however, my biggest concern is that these wires, if you look very closely, go inside the insation of the duct work and for as far as I could see were stripped from the wire insulation and ran directly aongside the metal of the insulated duct; this could become hot.
Dave Bush
MAB Member
Dave
"Rest Assured" that you client is in good hands with all. State the bottom of the line somewhere is "to be seen"
I think the above lost something in trans you lation
rlb
Richard B…
Man...my last post did come off like some killjoy jerk! ![icon_redface.gif](upload://f7DX2EWhmUfsDapWaYT3oJHMCj1.gif)
Sorry about that, I knew you were kidding.
Richard Moore
Seattle, WA
www.rainspect.com
Not a problem – I enjoyed it
It has been a long wet day
Have a good one
No problem at this end
RLB
Originally Posted By: dandersen
Mechanical Code violation.
Utilities can not pass into HVAC supply/return air duct or plenums.
Originally Posted By: jkormos
They wanted to burn the house down so they could collect the insurance money and have the job done right the next time icon_biggrin.gif
