Cantilevered deck construction
Yeah I agree. Kind of a half free-standing deck…lol. without a ledger board. What a mess.
Might be easier to write up what is correct on this one.
  1. Baluster spacing.
  2. ?
nice, saved!
haha, shut it… you werent supposed to remember that.
The ledger is supporting the upward thrust from the “cantilever” section
The entire weight of the deck is held up by the two center strap hangers.
This is an immediate hazard, and should immediately be blocked off from use.
Not cantilevered. “Hybrid Cluster F***” - A conglomeration of bad ideas that will likely result in death or injury. Have a qualified contractor or engineer evaluate it an suggested repairs. Maybe a total rebuild.
Sorry Daniel, your theory might apply if those added beams were supported down the middle from below, like a teeter-totter, in this case there is no support (nor a ledger) as they’re only attached by hangers, so all force is downward. Would’ve been a good area to close off with cautionary tape and tell the occupants to stay off until corrected.
Yes, I understand what you are saying… It is a miracle that floating area is even still there!!
I guess that beam is barely supporting it, through the few nails on those straps. As soon as a strap or nails break… see ya.
Yikes! Dangerous to say the least.
It’s one of those times you want to make it scary in the report, "Do not use deck until issues are corrected and made safe by qualified carpenter or deck builder…blah, blah blah
I love inspecting homeowner-built decks, always worth a good laugh.
