Capping off draining faucets at Boiler
Originally Posted By: dvalley
I’ve been seeing alot of capped off draining cocks at and around boilers lately.
The only problem is… These caps are hiding leaks. Everytime I find signs of leakage at a boiler, I look for the source and low and behold… The faucet was leaking but is now capped with a copper cover.
Someone tell me the dangers of these caps. Should these be exposed at all times or is it not a big deal?
I’ve been telling my clients that these should be replaced because of signs of leakage. What’s the dangers? icon_wink.gif
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: rking
David,
I would say that the faucets should be clear and in use (not capped). The faucets are a safety feature in most cases.
If you had to drain that boiler in a hurry you would be SOL if the faucets were capped.
Muskoka Home Inspections
"Wisdom is the Anticipation of the Consequences"
Steering Committee Member At Large
Originally Posted By: Steve Yared
I see capping them as no problem. The safety release valves are for safety, the valves are there for draining when needed. Just like a water heater drain valve, once you open them they never seem to close tightly again and drip. I recommend a cap on the water heater drain valve if it drips, if they need to flush water out the the water heater each month, why have the hassle of it dripping constantly.
Steve Yared
The Home Examiner LLC
616-776-7725
www.thehomeexaminer.com
Thanks guys,
Do I have any more recommendations? Should these be replaced? Or are the temporary caps good enough? ![icon_question.gif](upload://t2zemjDOQRADd4xSC3xOot86t0m.gif)
David Valley
MAB Member
Originally Posted By: gbeaumont
Hi Dave
I think you said it yourself with the phrase “temporary caps” I would take the view that the reason that the cap was there was solely due to the fact that the tap was defective and therefore like any other defective piece of equipment it needs to be serviced or replaced.
just my 2 pence worth
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
Originally Posted By: ismetaniuk
This membership was a big waste of my time!
Igor
Top To Bottom Inspections
Glen Spey, NY
Quote:
Ask yourself the question, Why did someone go through the trouble to manufacture the damn caps in the first place. If they do the job, then use them.
Thanks for the suggestion.
I did ask myself that question and realized that I had an answer too.
I'll write it up as a possible leak and recommending a new replacement drain faucet.
Geeze, that was easy. I wonder if I can answer all my questions the same way. I'm going to try that again on my next multiple tap in a SE Panel.
If it doesn't work, I'll holler for Dennis. ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
David Valley
MAB Member
Originally Posted By: jremas
Just make sure that the cap is not on a TPR pipe!!! If they leak then there is a real problem that needs attention.
Jeff Remas
REMAS Inspections, Inc.
Northeastern PA & the Poconos
www.NEPAinspector.com
570-362-1598
Originally Posted By: jmyers
Ok, everyone has valid points so if you want to have the drain valve replaced go ahead and replace it, if not I don’t see the caps as a problem unless they are permanently attached, meaning they can not be removed. icon_biggrin.gif
Just my 4 cents worth.
Joe Myers
