I would flag anything that does not meet current safety standards (e.g. IRC or CodeCheck) concerning both CO detectors and smoke detectors. Some inspectors write that up as a “Concern” or “Safety Hazard”.
I tend to agree with the flag as a "Safety Hazard", as in my opinion the newer requirements for interconnected and hardwired smoke detectors and CO detectors are the single biggest life saving provisions ever put in the model codes. Houses are made primarily of wood which burns pretty quickly, and generally do not have mechanical ventilation to help alleviate any possible CO buildup. So those devices really save lives.
Also, I wouldn't get into recommendations concerning the type/model of a CO or smoke detector.
-- Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: bkelly2 This post was automatically imported from our archived forum.
I do not use any specialized equipment. My own opinion is that by using more sophisticated equipment I am opening myself to more liability. My other thought is if one is using specialized equipment it had better be calibrated correctly, and include calibration records/documentation.
BK
-- "I used to be disgusted, Now I try to Be amused"-Elvis Costello
abishop wrote:
What kind of CO tester are you as an inspector using and if you detect or don't detect it, how are you calling it out.
Just push the test button, and write it up if it doesn't operate. Document the method/outcome in the report. Anything beyond that and I think you are just asking for trouble.
Also, consideration should be given to recommending simply replacing all the CO/Smoke detectors/alarms in a home after closing. They are pretty cheap and the biggest life saving devices in a home ... plus ya don't want to have someone find out the hard way that they actually don't work the way they should ...
JMO and 2-nickels ...
Eagle Engineering ?
