I’ve been provided a copy of the city’s inspect report which had the following comments. I know that these issues will be subject to a re-inspection but i was more curious about whether a list of issues like this one is common or worse than average? Is any issue of specific concern?
Complete joint blocking at 2nd floor joists
Complete point load block from 1st floor down to top of foundation
Provide full bearing under garage man door
Squash blocks under 1st floor load bearing wall
Install studs directly under 2nd floor joist at 1st floor load bearing wall
Provide repair detail for cut LVL under garages sunken entrance
Yes, it was very unsettling reading that report. It appears that the framing inspection failed twice. I would appreciate advice on how to proceed from here. Should I keep an eye on anything in particular? The cut LVL definately caught my attention. How would that even get repaired?
Yes, it was definately unsettling reading that list. I would appreciate some advice on how to proceed from here. Should I be specially concerned with anything, or should I address anything with the builder, or just let them do their work. The cut LVL definitely got my attention. How do I ensure that’s fixed correctly, let alone identify it?
This is a new construction in Ottawa Ontario Canada. Again, i would appreciate some advice on, as a homeowner, how do I ensure the major issues are fixed correctly, let alone identify them? Especially the cut LVL.
Pretty common findings during new construction AHJ inspections. Once those are in the inspection records, they will remain until repaired and signed off by the AHJ. I have seen some early inspections with PAGES of items to correct.
Read line 2 of my response. The times for rose colored glasses are long over and every consumer must use whatever steps are appropriate to help ensure they are receiving what they are paying for.
