The common wall between the garage and house had drywall installed …
the garage ceiling did not … ( the house was one story … No living area above the garage ).
Should the Garage ceiling have fire rated drywall also ?
If the drywall on the “fire wall” doesn’t go to the roof then yes. IMO…
Thanks … I’m going to call it out …
Yep with @mdurante 's statement. You can get into a long list including penetrations etc., but that ceiling void is a No Go…
Furthermore, paper faced insulation must also be covered up.
Thanks … for the info
Got it !!!. … I will write it up
i’m curious of that diagonal 2x4. what that there for? looks like someone tore out the drywall and put that there as some kind of bracing.
