Condenser Unit mounting
I’m headed to an inspection on Monday, saw this picture online of the house. I’ve never seen a condenser mounted to the side of a house. Maybe up north because of snow, but i’m in central florida. Any ideas why a home builder would have done this and is this legit or a discrepancy.
Tweakers/Theft… Flooding… Line-set too short and don’t want hassle/expense, can’t solder/weld/braze!
That looks like a Goodman, check on clearance from the side of the home for airflow and service. I found this quickly, but Goodman may have specifics for that model.
Thanks for the info Brian.
Protection against alligator tail damage!
:rofl: :rofl:
When I see that in Central Florida, it’s either a flood zone or the builder is from a different part of the country and that’s what they do back home.
I see it for Mini splits occasionally but I don’t think I’ve ever seen a full sized 2 ton or larger mounted like that.
I have seen it in Europe and Asia though.
This recent one isn’t that high, but still elevated.
It’s done all the time in my area on new construction now. One reason is so the HVAC company can get it set prior to final landscape, and the unit isn’t effected by fill settlement later. Usually aren’t that high though. More like Dominic’s above.
I say three feet or more, the tech would never have to bend over :wink:
Makes it easier to inspect too. On the ground, one always seems to have to contort to unnatural shapes to get that data tag pic.
Unless it’s rained quite a bit before you get there…I forgot my kayak.
I would venture to guess that it was done to avoid overspray from irrigation. I agree with Brian, I would check the manufacturer’s clearance requirements from the house.
Would make it a lot easier for reading the service tag on Goodman units.
Us short people would hate it if the condensing fan motor had to be changed.
They are the worst, for sure.
When that is done it could also be because the ground is unstable and this would prevent the unit from sinking on one side or the other. Some of the more reputable companies up here do it because of ground frost heave during spring and fall. Don’t think that is a problem in Florida
Are you close to the coast? In a flood zone? I’ve seen it on the West Coast of Florida around the big bend.
To keep you dog from peeing on it.
Though the better answer is if the area is in a flood zone.
Beat me to it.
What, No hip waders? :zany_face:
