I am in the process of becoming a CPI member and wanted to know how you submit the mock inspections. I have completed 3 mock inspections and 2 of them still say continue. I don’t see a submit bar to click on.
Accord to Step #2 of the Home Inspection Checklist for Submitting Verified Mock Inspection Reports article, you would submit mock inspections here.
Step #2 says to write and submit. I have completed 3 but 2 still say continue. how do I know if they are submitted?
That tells me that you are missing critical information! Go back through and verify everything!!
Side note… I wasn’t aware that non-members can submit Mock Inspections. The fact you are trying to submit 3 inspections and you just joined 1 day ago, seems suspicious. Likely the system thinks so also!
That was helpful as I needed to complete more sections. I am a member of internachi just not a CPI member as of yet.
Not according to the Internachi Member list. What’s your Member number?
Did you check the left column? When you’re done it will have a grey circle with the number of things you missed by each category. You can’t proceed until you fix it. Hope that helps.
My internachi member #is 20102737
