This was about a 1940s house. The side walls in question looked like they had concrete block underneath judging by what I saw in the attic. There was cracking at the lintels on both sides of the house that extended beyond the lintels. My first concern was that the wall was bulging or the opposite but it really didn’t look like that. I also realize that rusting lintels can pop the mortar but these cracks seemed to go quite a bit beyond. Thoughts, ideas?
Looks like lintel lift of the brick veneer from here on both windows. The steel lintels need to be replaced with hotdip galv or stainless and the veneer repaired…
Urgent action is needed, or this crack will go further. As previously mentioned, the jumpers should be replaced and it is recommended to check the frame. I hope everything will be all right, the main thing is to fix this problem in time.
