On an inspection today of a condo with crawlspace, the floor in the crawlspace has a partial membrane with pea gravel. However all around the perimeter the footing tile is exposed and not covered with pea gravel. To me this is just not right, but would like other opinions and possible links to verify if the pea gravel should cover the footing tiles. First time submitting pictures, hope it works.
Didn’t smell all that musty, but there were numerous puddles of water on top of the plastic. No visisble plumbing leaks. It did have a continiously running Fantech exhaust fan discharging out of one of the crawl space wall vents.
PEX piping yanked out of its supports so HVAC could run flexible ductwork where they wanted. Ductwork improperly supported. Puddles of water all over what little vapor barrier there is. Lady just moved in in mid-February. Hire me to do a report to hopefully get contractor to come back and fix things.
