Dark Wire on Neutral/Ground Bus Bar
Hey everyone, I don’t have a picture of the whole panel but there is a dark wire on the neutral/ground bus bar. Is this legitimate?
I would say that your findings are legitimate.
Did you trace it back to see where the other conductors went?
Unfortunately I didn’t and I’m not able to go back and reinspect the panel. Would it possibly be taped a different color higher on the insulation? This almost looks like a service neutral but may be a bit small and it’s in an odd spot for that. Normally those are on a lug at the top or bottom of the bar.
That’s why you always take lots of pictures. Nobody is going to be able to help you at all with just this little picture.
I doubt it’s taped at all, but that’s prob the only real issue here.
Since this is a service it’s likely a grounding electrode conductor (GEC). A GEC is typically insulated green or bare but when insulated it can be any color other than the colors desinated for neutral or grounded conductors. A black insulated GEC is permitted without any re-identifiction.
I missed how you determined it is a service. :man_shrugging:
Can you help me out, Rob?
Edit: Oh…Grounding and grounded on same bus bar?
Yes the EGC’s and the neutrals on the same bus.
The size of the conductor which appears to be a GEC.
Also Christian said it looked like a service neutral.
The rest was an assumption. :crossed_fingers:
