230.9 Clearance from Building Openings.
(A) Clearance from Windows. Service conductors installed as open conductors or multiconductor cable without an overall outer jacket shall have a clearance of not less than 900 mm (3 ft) from windows that are designed to be opened, doors, porches, balconies, ladders, stairs, fire escapes, or similar locations.
A deck is in there somewhere. As long as you are 3’ away, leaning over the rail, you are barely legal. If it is not a solid barrier you would measure from the closest opening. As long as the fence in the area of the service is solid they should be fine.
