Hi guys
So it looks like someone had a custom idea for this underground URD cable… That or I am about to learn something new.
Underground URD cable run in ABS corrugated 4". Not sure if this is supposed to be a slip joint for heaving / settling or what. Anyone seen this before or have thoughts or insults to share?
The Gray conduit ends about 12" below the top of the ABS.
Are you sure it’s ABS and not HDPE drain pipe? If it’s a direct burial cable then there shouldn’t be any need for a sleeve provided it’s installed correctly. Strange setup for sure.
There are utility companies that use corrugated conduit to pull their wires. I would call and ask the local power company if they do that in your area. BTW, where was the meter? on the house?
Good Point, The only concern I can imagine is a kid with a metal hot dog roasting fork, sticking it down there. I would like to see some type of cover or infill here. I am on the fence on weather to write it up or not.
If you are concerned, you could recommend sealing the opening. Normally, the SE requires protection from damage up to 8-10ft from the grade, but not in all places. Hard to child proof everything. What if he takes dad’s chainsaw to it There is only so much that can be done.
I had to look it up Robert so I knew what you meant.
URD= * Description: Underground Secondary Distribution Cables are twisted assemblies of aluminum alloy 1350 conductors insulated with cross-linked polyethylene.
