Not typically
I check for loose toilets and damaged shower walls, or loose tiles
I step along the edge of the tub and around the bath to feel if the floor is soft. and then visual of the underside if available in the basement of crawl.
I check around all toilets, floors around tubs and showers and all tile tub / shower surrounds. (except on slabs) It is used on every manufactured home with hardboard siding, and at the skirting / siding transitions. Also used in manufactured homes in laundry area and kitchen in front of dishwasher and sink. It is used on every home with hardboard siding in the places common for moisture damage.
Well! That was a complete no brainer…Yes!
So! CB found moisture around a forest of mold… Wow!
And he used his $20k imager to find it…
Good work CB!
What an incredible find…Yep!
Well its like this I do that so some Dumb A88 like the ones in N Fla can not say its an old stain. You do know that mold can go dormant or is that over your head also.
