system
                    April 26, 2004, 12:00am
              Originally Posted By: jtedesco This post was automatically imported from our archived forum.
Question Received via Email posted here for discussion.
	  Quote:
	  Does a residential main service panel require a main breaker?
--www.nachi.org/tedescobook.htm
                system
                  2
Home Inspection 101
6 throws maximum for service disconnect.
                system
                  3
              Originally Posted By: dedwards This post was automatically imported from our archived forum.
Ditto…What he said.
                system
                  4
Like them other guys said
regards
Gerry
--education@nachi.org
gbeaumont@inspectiondepot.com
                system
                  5
              Originally Posted By: loconnor This post was automatically imported from our archived forum.
6 throws maximum for service disconnect???
Please explain. Some of us are not quite
up to speed on shop talk lingo.
Thank you
--http://www.w-michigan-nachi.org
                system
                  6
              Originally Posted By: Ryan Jackson This post was automatically imported from our archived forum.
Larry:  If you can’t shut down the
whole building  with 6 or less circuit breakers you have a problem.
                system
                  7
              Originally Posted By: jfarsetta This post was automatically imported from our archived forum.
“The rule of sixes” applies…
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
                system
                    April 27, 2004, 12:00am
                  8
              Originally Posted By: dvalley This post was automatically imported from our archived forum.
The service disconnecting means shall consist of not more than six switches or circuit breakers mounted in a single enclosure or in a group of separate enclosures. –David Valley MAB Member
http://www.masscertified.com
                system
                  9
	  jfarsetta wrote:
	  "The rule of sixes" applies...
                system
                  10
              Originally Posted By: Mike Parks This post was automatically imported from our archived forum.
Ryan
"Larry: If you can't shut down the whole building with 6 or less circuit breakers you have a problem."
Not necessarily true.
Mike P.
                system
                  11
              Originally Posted By: Bob Badger This post was automatically imported from our archived forum.
OK 7 if you have a fire pump, not a normal dwelling unit feature.
–ECN Discussion Forums Mike Holt Code Forum
                system
                  12
Bob
Guys and gals some of what we post confuses you, as it should. Why we do this is to show you that the tradespeople do not always agree.
For me I do it because the others that post make me think. And, I do what to help to give you good information.
Mike P.
                system
                  13
Mike:  Are you trying to be an instructor or something?  Why bring up an issue to confuce people intentionally when it doesn’t apply?  Why would a home inspector care about the fact that tradespeople don’t always agree?
                system
                    April 28, 2004, 12:00am
                  14
              Originally Posted By: Steve Yared This post was automatically imported from our archived forum.
I have a general question on some of the items we report, like the 6 breaker rule.  It’s in the NEC, so does that make us code inspectors?  Does it really matter that there are 6 switches instead of 7 or 8 or 9.  BTW I do report the 6 switch shutoff to clients because that’s the way I was taught, but sometimes I wonder what the issue is with it.
–www.thehomeexaminer.com
                system
                  15
Theoretically, the NEC (and other authorities) implement codes for reasons of safety. Our job is to report on (among other things) safety concerns. If the NEC feels that 7 breakers is too many and therefore unsafe, we, as “generalists,” cannot argue this matter.
                system
                  16
Ryan
It is to show them that when they make 'code' statements, they are doing something for which they are not 'qualified' to do so.
Let me ask you this.
As a certified inspector do you feel that non-certified persons should be commenting on things that are out of their field of expertise?
I am trying to keep them from saying things that they can not back-up in court.
Mike P.
                system
                  17
	  Mike Parks wrote:
	  Bob
WE
WE  I disagree! I came here to help the Home Inspector's. I wish you would do the same!--www.nachi.org/tedescobook.htm
                system
                  18
              Originally Posted By: jpeck This post was automatically imported from our archived forum.
	  Mike Parks wrote:
	  Ryan
                system
                  19
If you disagree with me please quote a specific line.
Saying that you do not like my statements says nothing.
I do not mind to be proven wrong.
NOW show me where I have done anything NOT to help or INFORM.
I have never said that HI's should not look at electrical. I just do not want them to cross the line.
Joe and Jerry
You are both certified. Please show me the line. IE where does a HI cross the line.
Mike P.
                system
                  20
