Doing a 4 point inspection this looks like a double tapped main breaker I know some breakers this is allowed because the breakers are made for this purpose this appears to be a ITE breaker. Could somebody shed some light on this. Thanks in advance
Looks like a triple tap to me!
So that is definitely not okay this breaker is not designed for that correct
And not okay. Besides the triple tap the terminals are corroded and the only possible fix is a replacement.
Multiple issues can come from this scenario. Potential for loose unreliable connections, arching, over heating( Fire hazards ) main wires-strands trimmed to make them fit, may even have copper/aluminum wire mixed on same lug which is not good either, or simply overloading the fuse/breaker. Write up what is there and refer to qualified electrician to repair! Good Catch!
nothing looks ok there…
Are you kidding me? What are your qualifications? Who the hell trained you?
Jeesh
Nothing is okay about that. Write hard on that one.
Really what the hell are you talking about I posted a picture of what I thought wasnt right but there are breakers that can and are designed for double taps. Certified master I call you a certified failure
Internachi is supposed to be a community of inspectors that help each other out . But apparently your not one of those people.
And u directly insult me you should have your CMI taken away you give CMIS a bad name
I knew the situation wasn’t right so I figured I would go to the pros to confirm and this is what I got who the hell trained you yeah your supposed to be a CMI but apparently your a CMI bully
Well I waiting for your next demeaning comment
You post doesn’t even deserve a answer Merry christmas
Empathic yeah your a model of what a CMI should not be
Scott,
Just post your questions and ignore the negative comments. There are many here who will try to help you without judgement.
And Yet Robert He really seemed to need to rant much more than he needed an answer…just sayin,
There is no double tap or double lugging on anything
calm down Dennis get some sleep You will see better in the morning,
