Do any of the inspectors in NJ/CT/NY/NH perform drain/sewer scope inspections as an additional (or free-standing) service? I understand these fall outside of the standard home inspection scope.
I have a client who needs sewer scope inspections at several commercial properties, and we’ve had mixed results working directly with plumbers in the past.
What has been this group’s experience with sewer inspections? Do you ever perform them? Do you have recommendations for companies or inspectors that do?
Just a consideration and I am not in your area, but this came to mind. This is a completely different service from anything home inspection related. Local laws may govern you and your insurance provider may not cover scopes or (potentially more important) commercial inspection services.
I don’t do them. Mainly because I don’t like touching poop, but also because so many old cast iron drains require destroying the clean out cap (if there is one) to remove it. Then you need an assortment of supplies to get everything fixed back up, and I don’t want to turn my truck into a drain repair truck. I have a few companies I refer clients to when asked.
Luckily, many cities in my area are requiring a sewer scope prior to sale, so typically the seller takes care of it prior to the home inspection stage.
Get training. The number one complaint in Colorado about home inspectors is aimed at guys doing their own scopes. Saying a line is bad and it isn’t or the reverse, saying it is good and it isn’t. IMO, Jim Krumm’s course through NACHI is mandatory for someone wanting to start doing scopes.
I don’t do scopes. I have several subs that I contract to do scopes on my inspections and I collect a small concierge fee for scheduling them. Consider this, a busy inspector doing ten inspections a week, might have seven scopes. The techs that I sub out to, do more than that a day. The guys I use, have done over 70,000 scopes so far. It’s darn hard for any inspector to come close to that kind of experience.
When I watch one of those guys sit on a 6/12 roof scoping down the roof stack, I think, “glad it’s him and not me.” Sure, many scopes are easy. A couple of days ago, the sewer line was a 25’ long PVC. The dude was done in ten minutes. He spent more time setting up and putting away than doing the scope. Good for him. I’ve been with him when it took an hour and half and multiple locates and a lengthy explanation to the client…and I paid him exactly the same amount.
Still, I understand why many inspectors are doing scopes, particularly if they only do one inspection a day. I am often doing two inspections a day, and I don’t care much to have a couple of difficult scopes make my ten-hour day longer.
Edit: As I am finishing this comment, one of my scope subs sent me a video of a broken line in a commercial building gushing a torrent of waste water. It just happened to him on a job. The inspector bumped the line while the tech was setting up to scope it and a Fernco joint came apart. Literally a flood.
I do them and have avoided the issues others have raised by making it clear up front: I only perform sewer scopes if the drain line is readily accessible from a clean out. I don’t have to worry about breaking clean out caps, removing toilets, accessing the drain through a vent etc.. Clients and agents understand that limitation on my service up front and 99% of the time around here, the drain is easily accessible. If my competitors break and repair clean outs, remove toilets, and try to access drains through the roof, more power to them. I don’t mind losing the business to them.
I’ve had thousands of scopes performed at my inspections over the years and feel it’s tough for the HI to incorporate into the routine. Mainly, it’s a time thing. Buyers, agents and sellers expect things to be done in a few hours. A scope at the beginning or end can add a lot of time. Of course, newer houses can be done somewhat quickly and if I were to take it one I’d limit it to that for sure.
After the time thing, the equipment is expensive and a PITA to haul around (and coincidently, smells like ass in your vehicle). Training? Yeah, there’s a learning curve for sure. For me, having watched thousands this is towards the bottom of my list of negatives but it’s really nothing a new inspector should be taking on IMO.
