Drywall knockdown texture problem
I sent this message out, but I think it may have been done wrong previously. I am taping and floating in my garage and I am applying texture knockdown. I’m applying with the sponging technique. You can probably see where there’s a lot of grouping and appears as smearing in the area that I did the knockdown. I get the joint compound to pancake consistency and I let it sit for about 8 to 15 minutes, depending on how quickly it starts drying. I’m using the latest tools to do this technique and I pull at a horizontal angle on most very gently. But as you can see there is definite, pushing over and grouping. Plus, there are some stringy areas. Usually, I think drywall experts call this smearing. But the issue is when I pull across, the peaks are already hard enough to where they do not drop. But if I do it too early, the peaks will clearly smear. I’m almost thinking maybe I’m putting too much on? Can somebody please give me some text assistance on this?
Consult with a drywall contractor, not home inspectors!
I think you’re posting on the wrong page
If you’re not using a hopper gun, you’re not using the latest tools.
Wrong forum. Try here: https://www.diychatroom.com/
I’m confident that someone can, and will, assist you if you post your question in a DIY forum.
giphy
Guys, it’s not like a DIY’er hasn’t posting here before looking for advice and someone with the experience or knowledge giving it to them.
My son has been in drywall finishing for nearly 30 years. I’ve worked on the same job as him, I’ve subcontracted him several times, and he laced the ceilings of my last three properties.
The OP’s drywall mud is either too thick, he’s letting it set up too long, or both. I’ve never heard of the “sponging technique”, but I imagine that it’s probably not putting on a thin, consistent layer.
The best way is to use an air hopper to spray a thin even coat and letting it set up for 20-30 minutes, depending on the humidity, before knocking it down.
Typically back in the day drywall finishers would trowel on a thin layer of drywall compound and then use a round stippling brush to texture the compound and then skip trowel to flatten the high spots, its a talent to get a consistent look.
Drywall knockdown texture can be almost an art. there are many variables. Mixing the mud, how it is applied, how long you let it “set” before you knock it it down, what you knock it down with etc. as well as many others.
