I ran 2 moisture readers which said dry and ran a thermal scanner on them and it looks dry but I’m not expert.
I’m not sure these are new water spots being developed or not. I can confirm the texture in these spots for sure seems different as if some type of touch up was done in the past.
Observations: That there are two fully-separated spots leads me to believe that it was likely not caused by a single water leak. The spots appear lighter in color, whereas a water stain would most-often appear a bit darker with some rings around the edges. It does not look like it is due to a repair, because the ceiling texture is undisturbed. It is perhaps something else, like a contaminant of some type that leached through the ceiling and caused some bleaching. Have you looked in the attic to see what, if anything, is above that location? If you can safely get to that location in the attic, you might take a peak under the insulation.
Looks like missed paint. I do a lot of 12 month warranty inspections and can’t tell you how many times this is discovered because clients just don’t look up at their ceilings. It doesn’t look like a water stain to me but why don’t you climb into the attic and see what’s going on?
What is above this area? attic? if not, what is above and near this area, any bathrooms? It just spots, you have provided no information to even attempt to deduce something.
Light dirt or grease on the ceiling surface before the paint was applied. Water stains will show as brown misshapen rings around where the water first contacted the sheetrock. Purely cosmetic, does not indicate a larger problem.
There is nothing above this area, no bathroom it’s literally the middle of the hallway on the main floor.
Furthermore right above the ceiling directly where the spots are is the giant AC supply duct which is just air flowing through it through the house.there is no vent directly in this area either. Closest vent is 15 ft away.
I have attached a photo also of the thermal reading
Are you sure it could be something leaching through.
I have added a video that for sure looks like this is a different product on these spots. These spots are much smoother then the rest of the drywall and the entire drywall ceiling has a sparkling reflective feature to them but these 2 spots have no sparkling feature to them at all.
Nobody can be certain of anything as we aren’t there to see with our own eyes. Photos are generally always useless to make a determination of anything of this manner.
Looks like you have your answer. If that isn’t good enough, hire a professional to come out and take a look in person.
Pin moisture meter (a good one) is going to be your best indicator for moisture. Thermal imaging is great but only under certain circumstances I am not going into here. If it is dry…nothing to worry about. Not sure what is above this ceiling, but plumbing, roofs and HVAC may all leak under different conditions.
