I am wondering if there is a way to tell if it is EIFS or stucco? I am looking through my resources and can’t seem to find my notes. Any help would be appreciated.
Rap on it with your knuckles and you will know.
I assume that a “hollow” sound is EIFS? Is that the only way to tell?
Yes and drilling a hole will confirm it.
EIFS = sorta like styrofoam. You’ll be able to tell
Dallas, TX EIFS, Stucco and Siding Inspector advises searching his website http://www.adairinspection.com/EIFS-Stucco-Siding-Inspection-Home-Inspection-Commercial-Inspection.php
Thanks Michael, fixing the dead link today hopefully
Thanks Barry. Good info.
This link does not work http://www.apexhomeinspections.biz/articles/EIFS%20guide.pdf
These are cutaway views of the walls for the InterNACHI EIFS course now being edited for release. Three out of five have no foam and don’t sound hollow when you knock on them (I just did) but they are not hardcoat stucco.
I didn’t even know what I didn’t know about EIFS until I sat through the class. I handled the boom mike and so wasn’t able to really concentrate on the instructor, but I picked up enough to know that inspectors need to understand what they’re up against. Google research won’t do it.
Good pics.
WITHOUT FOAM IT IS NOT EIFS …better review Ron’s course and explanations of what you have depicted…you’re confusing our members by depicting this misinformation
I’ll post these for reference (from the InterNACHI EIFS course now being edited for release) but since I was working and didn’t actually complete the course I won’t comment on them.
I’ve seen stucco over Durarock (photo#2) used for indoor walls for an indoor pool but that is not EIFS as Barry clarified- EIFS has a foam backing. That’s how it gets its name.
Looks like GRAY STUFF to me. Yep, looked again definitely GRAY STUFF,
Mike it is EIFS like the stuff they coat Walgreen’s with.
You can push your finger through it.
Stucco feels hard like a plastered wall with real Lath.
[FONT=Arial][size=5][size=4]Comparing and Contrasting Hard Coat Cement Plaster (Stucco) and Exterior Insulation and Finish Systems (EIFS)[/size][/size][/FONT]
[size=5][FONT=Arial][size=4]A case study in enhanced performance[/FONT][/size]
[/size][FONT=Garamond-Italic][size=1]EIFS/Stucco White Paper[/size][/FONT]
[size=1][FONT=Garamond-Italic]2007[/FONT][/size]
[size=2][FONT=Arial][size=2][FONT=Arial]Introduction:[/size][/FONT][/FONT][/size]
[FONT=Arial][size=2]Architects, builders and owners have options when choosing a wall cladding. Among those options are two[/size][/FONT]
[size=2][FONT=Arial]cladding choices that are often compared to each other-cement plaster (stucco) and Exterior Insulation and[/FONT][/size]
[size=2][FONT=Arial]Finish Systems (EIFS). While there are some similarities between stucco and EIFS, there are also significant[/FONT][/size]
[size=2][FONT=Arial]differences. There is also confusion. It is important to remember that stucco and EIFS are two different
claddings. In recent years EIFS has come to be referred to as “synthetic stucco”. This term is not accurate.
Simply stated, EIFS is not stucco, and stucco is not EIFS. This white paper is designed to help you better
understand the similarities and differences, as well as strengths and weaknesses of stucco relative to EIFS.
[/FONT][/size]
[size=2][FONT=Arial][size=2][FONT=Arial]The differences between the claddings:
[FONT=Arial][size=2][FONT=Arial][size=2]Stucco [/size][/FONT][/size][/FONT]
[FONT=Arial][size=2]is an exterior cladding that is applied wet in several stages and is typically comprised of metal[/size][/FONT]
[size=2][FONT=Arial]reinforcement (lathing), cement, sand, and lime. Stucco is mixed on site and applied in one to three coats.[/FONT][/size]
[size=2][FONT=Arial]Newly applied stucco is considered “hot” and is highly alkaline. Stucco’s total thickness can range from as little
as one-half inch (16mm) to seven-eighths inch (24mm) including the final decorative finish coat. Stucco is
typically painted. When installed properly stucco should be allowed to cure for about 28 days; and between
each coat, a fine mist of water should be applied to the wall to prevent cracking. These steps may be modified
depending on climate and application conditions.
[/FONT][/size]
[FONT=Arial][size=2][FONT=Arial][size=2]EIFS [/size][/FONT][/size][/FONT]
[FONT=Arial][size=2]is also applied in several stages, and some wet materials are used. While a variety of EIF systems are[/size][/FONT]
[size=2][FONT=Arial]available, the most widely used system sold in North America is comprised of insulation board that is adhesively[/FONT][/size]
[size=2][FONT=Arial]applied to a substrate with one or two layers of a thin base coat. Reinforcing mesh is included in each layer,
giving the cladding extra strength. Importantly, cure times range from 6 to 24 hours. The applications need to
be dry prior to moving onto the next step. A final textured finish coat is applied to the prepared base coat. This
matrix of mesh, base coat and finish is referred to as the EIFS Lamina. Total thickness of the lamina will range
(depending on finish coat thickness) from three thirty-seconds of an inch to one-eighth inch (3 to 5mm). EIFS
materials are prepared in factory conditions against rigid quality control standards to assure purity, consistency
and high quality. On site mixing is restricted to the addition, in small quantities, of Portland Type II or I cement to
the base coat mixture. EIF systems are based on advanced acrylic technologies - the same chemistry used in
aviation, automobiles, and glass laminating industries.
[/FONT][/size]
[FONT=Arial][size=2]So what are some of the claims commonly made about stucco, and how does EIFS compare in those[/size][/FONT]
[size=2][FONT=Arial]measures?[/FONT][/size]
[FONT=Arial][size=2][FONT=Arial][size=2]Stucco is one of the worlds’s oldest proven exterior wall systems.[/size][/FONT][/size][/FONT]
[FONT=Arial][size=2]Stucco is certainly one of the world’s oldest wall products. And there is a lot to be said for an old building[/size][/FONT]
[size=2][FONT=Arial]technology. However, when it comes to construction, old is not necessarily better. Modern buildings work[/FONT][/size]
[size=2][FONT=Arial]better thanks to new technologies. The development of lightweight, non-load bearing exterior walls is just[/FONT][/size]
[size=2][FONT=Arial]one example, and EIFS represent the ultimate in lightweight, highly insulated wall claddings. EIFS is an
[/FONT][/size][FONT=Arial][size=2]engineered wall system [/size][/FONT]
[FONT=Arial][size=2]that employs more recent design and building technology innovations. EIFS is also[/size][/FONT]
[size=2][FONT=Arial]proven, having been successfully applied to more than 400,000 buildings of all shapes and sizes in just the last[/FONT][/size]
[size=2][FONT=Arial]50 years.
[/FONT][/size]
[FONT=Arial][size=2][FONT=Arial][size=2]Stucco is more durable[/size][/FONT][/size][/FONT]
[FONT=Arial][size=2]Stucco is impact resistant, provided it is specified and installed properly. However, due to a lack of conformity[/size][/FONT]
[size=2][FONT=Arial]and consistency, stucco durability can vary widely depending on the types of lathing materials used and on-site[/FONT][/size]
[size=2][FONT=Arial]mixing of wet materials. In other words, [/FONT][/size]
[FONT=Arial][size=2]not all stucco is created equal[/size][/FONT][FONT=Arial][size=2]. In tests conducted by the NWWCB,[/size][/FONT]
[size=2][FONT=Arial](Northwest Wall and Ceiling Bureau) variations in the application and mixing of stucco related to a variation in[/FONT][/size]
[size=2][FONT=Arial]impact resistance of +/- 50-75%. Specifiers must rely on acceptable industry standards and enforce those
standards on the site during application. Because standards will vary by locale, the specifier would be wise to
consult a local plastering bureau.
An EIF system has excellent impact resistance, provided it is specified and installed properly. EIFS impact
resistance is derived from multiple layers of fiberglass reinforcing mesh that are installed in successive layers
within the base coat mixture. The EIFS industry has certain minimum standards for impact resistance based on
the wall’s location and intended use. EIFS impact resistance will vary based on the mesh used. The specifier
should consult the individual manufacturer and should describe in the specification how impact resistance would
be judged equal to the brand he/she is specifying.
[/FONT][/size]
[FONT=Arial][size=2][FONT=Arial][size=2]Stucco helps insulate the home or building[/size][/FONT][/size][/FONT]
[FONT=Arial][size=2]The energy savings in an EIFS building are significant. Homes and commercial structures clad in an EIFS[/size][/FONT]
[size=2][FONT=Arial]product help insulate on average 30% better than other standard cladding options, including stucco, brick, or[/FONT][/size]
[size=2][FONT=Arial]metal. Why? Plain and simple, insulation is a part of EIF systems. The design principles employed in Dryvit EIF[/FONT][/size]
[size=2][FONT=Arial]systems stop thermal shock at the outmost plane of the exterior wall. Stucco does not have the same capacity
to effectively stop thermal bridging as EIFS. [/FONT][/size]
[FONT=Arial][size=2]According to studies performed by the Oak Ridge National[/size][/FONT]
[size=2][FONT=Arial]Laboratory (ORNL) Dryvit EIFS had a whole wall R-Value of 12.9 compared to just 4.91 for stucco walls[/FONT][/size]
**[size=2][FONT=Arial]in identical laboratory settings. **
[/FONT][/size]
[FONT=Arial][size=2]Clearly, EIFS is a vastly superior insulator to stucco.[/size][/FONT]
[FONT=Arial][size=2][FONT=Arial][size=2]Stucco is easy to work with and offers more design and outcome flexibility[/size][/FONT][/size][/FONT]
[FONT=Arial][size=2]There are significant differences between stucco and EIFS regarding workability. For example, stucco weighs[/size][/FONT]
[size=2][FONT=Arial]10-14 lbs. per square foot compared to only about 2 lbs. per square foot for EIFS, making EIFS one of the[/FONT][/size]
[size=2][FONT=Arial]lightest weight commercially viable claddings to work with. The lightweight properties of EIFS has other benefits[/FONT][/size]
[size=2][FONT=Arial]beyond just workability, including reducing the weight (and associated costs) of structural members. Also,
because [/FONT][/size]
[FONT=Arial][size=2]s[/size][/FONT][FONT=Arial][size=2]tucco has higher expansion and contraction rates, more control joints must be used in stucco[/size][/FONT]
[size=2][FONT=Arial]compared to EIFS. The incorporation of control joints increases construction and maintenance costs and can[/FONT][/size]
[size=2][FONT=Arial]increase the cladding’s susceptibility to water penetration. Finally, while the exterior preparation for stucco and
EIFS are identical, EIFS offers a broader array of finish options and a more exact color consistency than stucco.
[/FONT][/size]
[FONT=Arial][size=2][FONT=Arial][size=2]Stucco is economical[/size][/FONT][/size][/FONT]
[FONT=Arial][size=2]Wall claddings need to be judged against several standards when cost is considered. These include[/size][/FONT]
[size=2][FONT=Arial]installation time, maintenance over the life of the cladding, and reduction of HVAC costs. While[/FONT][/size]
[size=2][FONT=Arial]installation costs will vary from region to region, it is vitally important that cost be evaluated by more than[/FONT][/size]
[size=2][FONT=Arial]simply installed cost. When the energy savings derived from EIFS, the less time required to install the
[/FONT][/size][FONT=Garamond-Italic][size=1]EIFS/Stucco White Paper[/size][/FONT]
[FONT=Arial][size=2]system, and the reduction in more costly structural members are factored into the equation EIFS has[/size][/FONT]
[size=2][FONT=Arial]proven its value time and time again.[/FONT][/size]
[FONT=Arial][size=2][FONT=Arial][size=2]Stucco is a natural, green building product[/size][/FONT][/size][/FONT]
[FONT=Arial][size=2]When assessing the green benefits of building products it is essential to look at the full life cycle – from the extraction of raw materials to manufacturing,[/size][/FONT]
[size=2][FONT=Arial]to transportation, to use and re-use. There are[/FONT][/size]
[size=2][FONT=Arial]sources out there to evaluate these factors with[/FONT][/size]
[size=2][FONT=Arial]third-party clarity. The National Institute of
Standards and Technology (NIST) offers
software called BEES (Building for Environmental
and Economic Sustainability) version 4.0 that
evaluates the green characteristics of more than
230 building products. [/FONT][/size]
[FONT=Arial][size=2]That data demonstrates[/size][/FONT]
[size=2][FONT=Arial]that Dryvit EIFS offers a substantially smaller[/FONT][/size]
[size=2][FONT=Arial]carbon footprint than stucco over the full life
cycle of the product
[/FONT][/size]
[FONT=Arial][size=2]. As the chart at left clearly[/size][/FONT]
[size=2][FONT=Arial]demonstrates, [/FONT][/size]
[FONT=Arial][size=2]Dryvit EIFS has a carbon footprint[/size][/FONT]
[size=2][FONT=Arial]that is more than two and half times smaller than[/FONT][/size]
*[size=2][FONT=Arial]stucco *
[/FONT][/size]
[FONT=Arial][size=2]over the life cycle of the products.[/size][/FONT]
[size=2][FONT=Arial]The data is overwhelming that Dryvit EIFS is a[/FONT][/size]
[size=2][FONT=Arial]greener building option than stucco. The NIST
analysis measures the products by 14 metrics in the software and EIFS consistently fares better than
stucco in each measurement.
[/FONT][/size]
[FONT=Arial][size=2][FONT=Arial][size=2]Stucco is a sustainable building product[/size][/FONT][/size][/FONT]
[FONT=Arial][size=2]Stucco is, with the exception of the important metal lathe component, a natural product. But with Dryvit EIFS[/size][/FONT]
[size=2][FONT=Arial]and the DryvitCARE program you have a product that never has to be recycled. The DryvitCARE program, a[/FONT][/size]
[size=2][FONT=Arial]systematic care and maintenance program, ensures the long-term performance of the building’s exterior by[/FONT][/size]
[size=2][FONT=Arial]diagnosing and repairing potential issues in the wall before they become problems, and providing the building
owner with a renewable warranty. With DryvitCARE you get a building material that will never need to be
recycled.[/FONT][/size]
[FONT=Arial][size=2][FONT=Arial][size=2]Stucco offers great aesthetic value[/size][/FONT][/size][/FONT]
[FONT=Arial][size=2]Here there is no comparison. Stucco comes with a standard look that is typically altered only by paint. EIF[/size][/FONT]
[size=2][FONT=Arial]systems come with numerous textural and color options that are not available in the traditional stucco system.[/FONT][/size]
[size=2][FONT=Arial]With EIFS you can get a wall that looks like brick, limestone, granite and aged Italian plaster, in addition to all of[/FONT][/size]
[size=2][FONT=Arial]the cementitious, stucco-like options.
In sum, there [/FONT][/size]
[FONT=Arial][size=2]are [/size][/FONT][FONT=Arial][size=2]significant differences between stucco and EIF systems. Before making a cladding selection[/size][/FONT]
[size=2][FONT=Arial]all factors should be considered and a design professional consulted.[/FONT][/size]
[size=2][FONT=Arial]For more information of Dryvit EIFS visit us on the web at[/FONT][/size]
[FONT=Arial][size=3]www.dryvit.com[/size][/FONT]
Our online video EIFS/Stucco course will be released within a week (I think). It was shot at this class: http://www.nachi.org/stucco2008.htm
Nick, InterNachi’s online training is terrific! Can’t wait to see the upcoming course.
Inspection Tips for Stucco and EIFS by Ron Huffman
the link has been fixed
http://www.apexhomeinspections.biz/articles/EIFS_guide.pdf
