Sure glad to hear from some of the new kids who understand the intent of my post.
I have been criticized by someone recently here on this forum for trying to teach the NEC to the Home Inspector, how many NACHI people are qualified to teach the NEC? Not you Bubba! Please let others come forward!
I would like to hear more about new construction inspections … you check box fill and all of the items that the City Inspector’s check?
Many areas have not adopted ICC based model codes like the IRC, or have local requirements that are more restrictive (like in your area with restrictions on sheathed cable wiring for example). It is still an excellent reference for HI’s, and many preach the use of the IRC based CodeCheck series by HI’s regardless of what model codes have been adopted at the state/local level. You just have to be aware they are not the legal requirements, and there may be local restrictions.
I was using references like the CABO code (predecessor to the IRC) and CodeCheck as a guide for home inspections well before my state adopted ICC codes in 2003. Worked very well as a guide.
I have done code compliance inspections as a former chief building inspector for a local municipality, and although there are some common elements a home inspection is completely different. Unlike code officials, home inspectors just need a working knowledge of major model code provisions as a guide, and the practical application of those provisions. As far as checklists, CodeCheck is indeed a widely referenced HI guideline.
For example, box fill should be checked on a code compliance inspection based on the number and type of cables for a given box size. However, as part of a phased home construction inspection it may become an issue only if it looks really bad (in which case it probably is well beyond the acceptable limits). It would also be written up differently, possibly as a “safety concern” with a practical explanation and recommendation for further evaluation, and not as a “violation” with just a code reference section that requires correction.
You hit it right on the head. There are very few “safety concerns” that will leave you open to ligitation. Quote code and you can find yourself in deep ka-ka!
P.S. I agree, well said Gerry. I also teach a class on Building Codes for Home Inspectors, and I will usually start directly quoting code sections (say some of the NEC grounding and bonding provisions … ouch) … and I start seeing the eyes roll up and stars flying around their heads (the desired effect…:)).
Then I explain the practical reason behind the code requirements, and how to apply that to what is observed on an inspection (with a code section reference as just back up)… and then the light bulb goes on. It’s amazing …
