Performed an inspection last week. Had an issue where a stranded wire was split and shoved under either side of the breaker’s lug in the main electric service panel. Reported this as incorrect and a qualified electrician should repair.
Seller’s realtor reports: electrician insists there is no problem with this, though he could put smaller connectors on, but then you’d have to add a wire nut to the wire (i.e. MORE connections). Electrician says it is solid and not loose and there is no problem.
What I need is some clarification or code to give to the realtor to back up my findings.
If She has an electrician who will take the liability of saying it is fine then You are done imho…let Him write a letter on His company logo stating so and it’s all good…You reported what You saw …
So you’re guessing that it’s actually larger than a #6? Could be, maybe I should have said it appears to be at least a #6. A 20 amp QO CB is listed for a #8 conductor.
15 A. 1875 W. 125 V. Gas range adapter converts 220 V to 110 V. Grounded. Simply plug gas range into this adapter, then into the existing electric range outlet. Built-in 15-A fuse for safety.
