EPDM Roof
Did an inspection on a small cabin and it had a low sloped epdm roof. I noticed that with the wind blowing I could see the rubber ripple under the wind. Is the epdm adhered with a mastic? the seams and edge seemed to be held down by mastic, but not the main part of the membrane. Any thoughts?
Originally Posted By: bkelly2
Kevin this might help. look at the installation page.
http://frs.flatroofsolutions.com/
Thank you…that was helpful.
Brian:
Thanks for the Link. ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: dvalley
Kevin,
I've seen all sorts of Rubber roofs that contain ripples and massive air bubbles under them. I've recommeded a roofer evaluate every one of them. I had one rubber roof that was sealed at the edges only. As I walked on the rubber, I felt like I was on a trampoline. I Red Flagged it.
These rubber membranes need to be secured (glued) throughout the entire roof.
Air bubbles and major ripples should tell you that they are not secured properly.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: randerson1
Kevin,
I installed one for myself and the instructions had me glue down the entire roof. Big pain to get all air bubbles out!! Not sure how the roofing companies do it but the manufacturer of the stuff I used would not warranty it unless it was glued down.
http://www.inspectatoz.com
Work hard, play hard. and live long.
