ccurrins
(Christopher Currins, CMI®)
November 20, 2012, 3:17am
21
The top should have Z-Flashing, no caulk at bottom.
When installing James Hardie products all clearance details in figs. 3,4,5,6,**7,**8,& 9 must be followed.
Maintain a 1/4" clearance
between the bottom of
and horizontal flashing.
Do not caulk gap.
http://www.jameshardie.com/pdf/install/hardieplank-hz5.pdf
belliott
(Bob Elliott, 450.0002662)
November 20, 2012, 3:53am
22
ccurrins:
Do not caulk gap.
Chris not sure what you are looking at but the z flashing is at the bottom and as stated in this thread my question was about the top which is caulked.
The top is caulked at points where it meets wood and is flashed (z flashed) at bottom of the vinyl siding.
Show exactly where in the Hardie PDF top flashing or sealing is explained.
ccurrins
November 20, 2012, 4:19am
23
Here is a much better description .
Page 3 Figure 8.8
Flashing needs to be
tucked under the water
resistive barrier and
over the Flat Tabs.
Also see Figure 8.21 page 7.
ccurrins
November 20, 2012, 4:21am
24
Here’s James Hardie Best Practices ](http://www.jameshardie.com/homeowner/bestPractices.shtml ) Installation Guide Siding and Trim Products
belliott
November 20, 2012, 4:38am
25
OK will check it out later .
To mad to read much right now after the M N f beatdown
