Inspected this 1960’s home today and thought that the home had been rewired with grounded circuits. The 3-prong receptacles tested OK (grounded) with my 3 lite tester. When I opened the distribution panel, I did not see any grounding conductors, all 2 wire. Removed a receptacle and here is what I found. My question is would a sure-test indicate this false ground? What would this set up do to a appliance with a ground (3-prong plug) if current traveled back and energized the appliance. Looks to me like a real safety hazard. What do you guy/gals think?
jpope
(Jeffrey Pope, CMI, CHI, CPI, ICC)
April 7, 2006, 11:49pm
2
Yes, a SureTest would have indicated this condition.
gbeaumont
(Gerry Beaumont)
April 7, 2006, 11:54pm
3
Hi Steve,
Yes my Suretest 61-165 will show false/bootleg grounds but I believe that the cheaper ones do not, it would be worth researching the ideal website to check.
Any appliance that has a three prong plug is designed to work with a gronded conductor. Some electronic components especially computer equipment does not work well on 2 wire circuits. and yes there are angers associated with connecting the Neutral to the ground at any location other than the service panel.
Regards
Gerry
This find today has convinced me to invest in a Sure-test. Thanks for your help.
jpope
April 8, 2006, 12:05am
5
Gerry meant to say groundING conductor. . . Oh, and I’m sure he meant D anger rather than anger. .
Startin’ Friday a little early eh Gerry
gbeaumont
(Gerry Beaumont)
April 8, 2006, 12:19am
6
jpope:
Yeah what Jeff says :mrgreen:
I have been writing a class all week and I’m getting punchy now I am going for a brew
Regards
Gerry
rbennett
(Richard L. Bennett, RETIRED)
April 8, 2006, 12:45am
7
An off the shelf VOM will show the boot leg ground
Cost about $25.00 from radio shack
If you have the $$ spend it on the big boys
rlb
jwilliams4
(Jae Williams)
April 8, 2006, 12:46am
8
Gerry – Warm pint, no doubt.
gbeaumont
(Gerry Beaumont)
April 8, 2006, 1:14am
9
Jae, no, in fact they kicked me out of England because I don’t like warm ale, and I am sure as hell not drinking the tea
I spent way too long in Belgium, Holland and Germany sinking tall frosty lagers
I’m just going to raid the fridge and see if I have any Stella left
Regards
Gerry
rbennett
April 8, 2006, 2:26am
10
Please people
Do we all have to spend $$ to find this problem or can we find it cheap and dirty way with out doing a lot of work liking taking the plug apart?
rlb
Jay_Moge
(Jay Moge)
April 8, 2006, 2:29am
11
i don’t think i’m going to pull duplex outlets out of the wall. if you get a ground reading on you little tester, and theres not ground wire in the panel… guess what?
jpope
April 8, 2006, 2:34am
12
I would say yes. But that’s just me
rbennett
April 8, 2006, 2:35am
13
Jay
What if one could show you how to check for this problem is about 5 seconds??
Will someone else - Jeff Poe etc come in with the answer to the problem???
The ac voltage differenct between the ground and the neutral - Hi Z ???
rlb
tneumann
(tneumann)
April 8, 2006, 2:37am
14
Edgar Allan Pope will be along shortly…
I want a sure test just cuz it’s cool…sorta the same reason Jeff is Mr. Wireless now…
I don’t think I’ll be taking receptacles apart any time soon…the lack of ground in the panel would have been a red flag eh?
rbennett
April 8, 2006, 2:39am
15
Tony
I feel the answer is comming — stand by
rlb
Jay_Moge
(Jay Moge)
16
almost done #4 Tony, how you doing?
Jay_Moge
(Jay Moge)
April 8, 2006, 2:41am
17
rbennett:
Jay
rlb
if it’s easier than doing what i’m going to do anyway (check outlets with 3 light, and open panel) i’m all ears…or eyes:roll:
jpope
April 8, 2006, 2:42am
18
Not if the wiring was with BX. . .
jpope
April 8, 2006, 2:49am
19
You could measure the resistance between the grounding and grounded conductors (that’s what the SureTest does).
tneumann
(tneumann)
20
What should the reading be?
