Doing an inspection on a property this week. Client explained to me that he is an HVAC tech and noticed that there was no filter dryer on the liquid line on the exterior unit.
I don’t think I would have mentioned anything about this, but what do you do since the client has? Is it required?
So the client is a HVAC Tech. Does the client further evaluate? Curious in this type of scenario when clients are in a specific trade. Or should we just state " It was observed that the filter drier was not present on the exterior unit, further evaluation and necessary corrections are recommended if needed " ??
I have no way of qualifying my clients credentials so I act as if they do not exist. Even if I did qualify his credentials, I would not presume he was going to do the work.
Understand that and it makes sense. I did an inspection for a client that couldn’t be there for the inspection. I started explaining the issues in the report and he told me he understood every thing I was talking about. Turned out he was a retired builder and licensed in most all aspects of building. He appreciated my report…but we shared some laughs on it too.
I recently did a 1970 2 story on a basement with a huge old deck. My client was present and was a structural engineer. He understood everything during the walk-thru, it was actually refreshing because he understood and things went quickly.
Until then, we are on equal footing. What you will find is that there are varying opinions on the issue. And if I am wrong, I have no problem with that.
I want it to stand up in court no matter what. I never recommend DIY, ever.
So in court, my comment will read I recommended an action by a qualified person. That transfers the liability onto the client to determine the best person for the job.
Of course! And if the client may be qualified then a “qualified contractor” may be sufficient. You don’t have to specify them and in the same wording, you don’t want to demean them also.
