Sometimes the rating label that should be on the hinge side of the door edge gets painted over for older homes, in which case ya just check if the door is solid wood or hollow metal. The old hollow core wood garage doors are NG now as Andrew noted … which a few taps with the back of your screwdriver (ya have one of those, right … lol) should help ID …
For new construction, a label that isn't visible will not fly.
-- Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: ddivito This post was automatically imported from our archived forum.
Yes, the door needs to be fire-rated with a self closing mechanism. Has been since the 1920’s. Metal or solid core wood. Of course local building officials have the final say. Check with them. Quoting code is a no no anyway unless it is the local one. Even then, we are not code officials and the liability…?
