When a home has a attached breezway or enclosed patio between the garage & house is a fire wall & door still required?
Thank you
Dave
Thank you
Dave
As a fireman in Dallas for nearly 20 yrs, I don’t know if it is required, but it should be. Usually though, the fire will travel inside the breezeway/attic space on it’s way to the house. I would mention this as a fire safety issue at the minimum. There definitely needs to be a fire-rated system at the door and in the attic above - between the garage and house.
My .02 cents
Bruce
If I understand this correctly, it would apply if the attic space is connected between the two.
IMO.
Marcel
</IMG>
