Originally Posted By: aslimack This post was automatically imported from our archived forum.
Jeff,
Just wondering, was the suretest origionally used to verify that the outlet was an un-ground 3-prong, or was their reason you suspected something more diabolical?
Jeff P wrote:
When I pulled it out, the fireworks began. It took about 3 full seconds - of brilliant white light and the sound of bacon on the frying pan - to trip the breaker at the panel. You could have heard a pin drop afterward.
I still like Jerry Pecks "Failed under testing" comment
That's how the report reads!!
All accessible receptacles are tested - this one just so happened to be first. I'm not too sure what the problem was. The receptacle "shifted" when I unplugged my tester and apparently shorted itself somehow.
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: dbush This post was automatically imported from our archived forum.
Jeff, I had something similiar happen; however, it had a metal receptacle cover on it; and the screw was loose, so the cover came in contact with the tester. Client said “After that is fixed, I am going to remove all of the metal cover plates.”
Originally Posted By: Mark Dudley This post was automatically imported from our archived forum.
Looks like a metal box and you say the outlet shifted when you removed the tester. It probably pushed the terminals against the metal box and viola, instant short.
That's why I don't build with metal boxes..
Originally Posted By: jmyers This post was automatically imported from our archived forum.
Mark,
While I can understand your decision to use plastic, one of the big turnoffs to installing plastic is that some decided it was alright to be sloppy since the potential to harm was minimized. Now, instead of the receptacle shorting out on the box, it just pulls completely out of the wall.
I dunno… someone that is going to do sloppy work is probably going to do it whether it’s in plastic or metal. About the only time I see metal boxes in new construction now is when conduit is used (especially on commercial), or the outlet is for a ceiling fan or hard wired electrical appliance (such as a dishwasher).
Originally Posted By: pdickerson This post was automatically imported from our archived forum.
Wow, great story Jeff! Please keep us updated if their are any further ramifications. I had an owner get upset when his already broken kitchen sink p-trap fell into several pieces when I touched it. He said “it worked when you arrived, and now it doesn’t, so you need to pay to have it fixed.” Has the owner of the fireworks home held you responsible for the repairs?
Also, what brand of circuit breaker took 3 full seconds to trip under what sounds like a direct short? It should have tripped in 3 milliseconds. Yikes!
Originally Posted By: Michael Martin This post was automatically imported from our archived forum.
Um… I meant “right,” not “tight.” Also, I know there are time curves for breakers to trip, but it sure seems like three seconds at a dead short is more than enough time to ignite nearby combustibles. Properly sized, I prefer fuses…
