First Inspection!!
Originally Posted By: jbranam
I just got a call for my first Inspection(with my own company).
I cant wait! NACHI has really helped me with getting started. I couldn’t have done it without them. I hope it the first of many.
THANKS NACHI!!!!
Originally Posted By: jjackson1
Busted mine yesterday. Go get 'em!
Originally Posted By: kwilliams
Member - MAB
http://www.nachi.org/convention2006.htm
Originally Posted By: chorne
congratulations guys!
Originally Posted By: jkormos
Originally Posted By: aleleika
A. Dan Leleika
www.a-teamhomeinspections.com
Originally Posted By: bsmith
Congrats guys! May many more follow.
Bill Smith
www.SmithHomeInspection.com
“The difference between stupidity and genius is that genius has its limits.” A. Einstien
Originally Posted By: jrivera
go get’m boyz !!!
Originally Posted By: gporter
Market, Market, Market.
Gary Porter
GLP’s Home and Mold Inspections LLC
Orlando, Fl 32828
321-239-0621
www.homeandmoldinspections.com
Originally Posted By: tallen
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Originally Posted By: rhintze
Welcome to the neighborhood and congrats…I’d be happy to get together and talk shop. I’m about six months into it and with perseverance the business is growing. Got a call on Friday from N. Tampa through a referral (from two months ago) that turned into 2 jobs and an additional 20 sources of work. These came as a result of a previous customer ‘selling’ my services. Marketing is key, but doing a thorough and professional job is just as important. Give me a ring.
Originally Posted By: jonofrey
Congratulations fella’s.
I didn't know Todd was a code talker. Did you?
Inspection Nirvana!
We're NACHI. Get over it.
Originally Posted By: pabernathy
Congrats Fella…remember you have a BUNCH of great people here to help you along the way. Just come a calling if needed and again Congrats !
Paul W. Abernathy- NACHI Certified
Electrical Service Specialists
Licensed Master Electrician
Electrical Contractor
President of NACHI Central Virginia Chapter
NEC Instructor
Moderator @ Doityourself.com
Visit our website- www.electrical-ess.com
Originally Posted By: senomoto
The journey of a thousand inspections . . . starts with the first one.
We all had one.
Congratulations to you both.
Stephen Enomoto
Horizon Home Inspection LLC
"You expect the Best . . . We'll provide no Less"
The inspection went well. The client wasn’t a buyer or seller. he was worried he had a roof leak. of course there was no leak. He was pretty happy with the inspection, and said he liked following me around learning about the home he has owned for 21 years.
Congrats. #1 is an accomplishment and confidence builder! Sounds like you should ask to “quote” some of his comments to begin building your testamonials.
Curious- how did you write up that the roof didn’t leak? How old was the roof covering?
Originally Posted By: wdecker
John;
Some advice, if it would help.
With roofs, make sure that you inspect the outside AND the inside. Look for water staining in areas under where you are suspicious on the outside. Look on the decking AND the rafters. If you see signs of staining, check for active moisture with a good meter.
If you cant see the inside of the roof (not attic, no access) make sure you CLEARLY STATE this in your report.
Also, it is a GOOD thing when your client follows you areound and you give a running dialog of what you see (good and bad). It helps you to remember for when you write your report AND educates the client. When people learn new things (are educated) they feel good. They find out that YOU make them feel good. Don't lecture from a condescending POV, just discuss and make sure that you let them talk as well. In that wat, you make them interested and involved in the inspection. This is the best way to keep loyalty and get referrals.
After you hit the 50 to 60 inspection point, you will find more and more people coming to you based upon the refe4rrals of old clients. This is the sweet spot.
When you write your first report, you REALLY make sure that you get it right. This is normal. But, over time, there is a tendency to get full of yourself and skimp on the descriptions and such. Avoid this! Write each report with the completeness and diligence of the first. I regularly go back over my old reports and self critique myself to make sure that I am still sharp.
Good luck to you.
Will Decker
Decker Home Services
Skokie, IL 60076
wjd@DeckerHomeServices.com
http://www.nachi.org/bbsystem/usrimages/H/HPIM0113.JPG ]
Ceiling staining, especially on cathedral ceilings, is a sign of excessive moisture. I verify by checking the moisture content of the stain and the surrounding areas.
Bad ventilation in the cathedral ceiling leading to moistire buildup, aggrivated by lack of proper vapor barrier.
Will Decker
Skokie, IL 60076
