I do not see Z or cap flashing over these windows surrounded with faux stone and large gaps. Is this a standard installation that is acceptable? I want to write this as a deficiency but would like the advice of smarter people than me.
So this seems to indicate that there should be sealant around the window frame. Is that correct?
That’s the way I read it.
Here is the Masonry Veneer Manufacturers Association Installation Guide
Windows start on page 44.
It shows backer rod and sealant needed at jambs and sill and optional at head.
And continues with flashing info details, etc…
where are You located John? if that is dry stack stone and You are in a freeze thaw climate that veneer is just waiting to fall down one piece at a time…The windows may not be the big issue here…
The stone should have mortar in the joints, leaving it open will just cause it to fail.
That AMV has been installed improperly. The AMV should not be in contact with the window material. It should stop about 3/8 of an inch away, that gap filled with a backer-rod and then the proper sealant applied. Dow 795 is one of the better ones to use. I can see the metal lath, and that is wrong! That window should have head flashing. Im sure more details have been left out! Think of AMV as “Bumpy Stucco”! It goes up pretty much with the same details as hardcoat stucco.
Attached is the AMV Bible for installing it!
MSV_Install_Guide_5thEd_5thPrnt copy.pdf (16.5 MB)
Thanks Scott! Great information.
John Wheeler
Certified Master Inspector
Wheeler Home Services LLC
615 397-0975
That is called a “Dry Stack” look. Mortar in the joints is not needed with AMV since it is an adhered application and is held in place by the mortar on the back of the faux stone. Think of it as a finish coat on hardcoat stucco. But, the dry stack look is not the best application in cold zones as the constant freezing can cause the AMV to pop-off due to water freezing in the joints.
To clarify, are you saying the lath is wrong, or it should not be visible if the window frame is flashed properly in the opening.
Seeing the lath is wrong, it should not be visible as it should be covered with the scratch coat. This tends to reflect a poor attention to detail which is no suprise with all of the other issues.
So I guess this logic can be applied to floor tile as well. Grout not needed as it is adhered to the floor by thin set.
Without grout the stone and wall surface will eventually fail. There are tons of manufactured stone products on the market that crack and fall off the mounting surface every day. At least the mortar gives some protection.
Directly from manufacturer
Filling the joints in lieu of a “dry stack” installation
is recommended in freeze-thaw environments. The
adhesive mortar should be “thumb-print hard” prior to
pointing the joints. Installing a joint that is concave and
properly compacted will provide the best protection
against water penetration.
That is pretty much what I said in my post!
. Flooring tile and AMV are not even in the same family or category. But as you noted the manufacturer reinforces what I posted about dry stack installation not being the best option for areas that freeze.
We live in a freeze/thaw area and have installed a lot of this faux dry stack stone. If it is installed properly it really doesn’t have too much problem with falling off. The key is if it is installed properly.
That being said I personally hate the look and actually get more concerned about the numerous places that wasps can use for nesting.
Ditto for me. I saw dry stacked stone Friday at a house in the mountains. It had been there for many years and looked great. I think the conversation here about the potential problems is good, but for us in the field, we report our observations. IMO, I can’t observe twenty-year-old dry stacked stone that looks great, and advise my client that this is a potential problem.
