Any idea why flex duct would be routed from beside an attic heat pump to a roof vent? 1st time seeing this.
Have a photo? Year built? Year of heat pump? Model #?
I attached a couple of photos. Home was built in 2013.
Did it connect to return plenum? Fresh air intake for tight construction.
Is it ran from the HVAC return ? It may be a make up for a kitchen exhaust.
That does not look like it is connected to anything.
You’re right as I zoom in it appears to be just laying on top of the insulation.
I has never connected to anything, just laying there.
There’s no kitchen exhaust.
Either something changed… or perhaps it meant to serve a bathroom exhaust. We were not there
if it was not connected, it’s anyone’s guess.
Well, it might not be for the heat pump, or awaiting an air exchanger. Right now as it sits, it’s fairly static.
Is the heat pump new, or original to the house, 2013? What does the vent look like on the roof ( exhaust or intake)?
It’s original to the house. It terminates at a standard attic roof vent
I would chase down all the bathroom vents. Once those are eliminated you are left with a maybe.
Fresh air can be added to the HVAC system, but the photo is lacking those components such as a damper and filter.
Here is a little something on the subject. I’m sure there are better links FRESH AIR FOR VENTILATION AND BUILDING PRESSURIZATION | Contracting Business
I think Simon is correct.
Likely it was fro a make up air vent that was never connected though it’s unusual to see it terminate through the roof. Maybe they forgot. I’ve seen them forget several times…Sometimes they forget a proper termination outside or to connect it to the system at the air return…It’s insulated and typically around here bath vents, dryer vents and kitchen exhaust fans are not insulated.
